Central heating receiver not working - Salus RT500RF
brokencornets
Post by brokencornets »
Hi
My Salus RT500RF receiver is no longer working. The controller works fine and the boiler is working fine for hot water, however the receiver has no lights.
The receiver is on the same fuse as the boiler and the wiring is secure, it's been working fine for 7+ years but has suddenly stopped.
Is it just time to replace the central heating controls? Or could it be something more simple?
If I do need to replace, will all brands use a similar wiring set-up and therefore an easy like-for-like change?
Has thanked: 47 times
Been thanked: 2571 times
Have you actually checked for voltage at the receiver?
gas4you
Has thanked: 419 times
Been thanked: 900 times
Post by gas4you »
You have been lucky that a Salus has lasted that long!
I would replace it.
Dave
