Looking for this shelf bracket
- wine~o
- Has thanked: 1414 times
- Been thanked: 4015 times
It's called a twin slot bracket one example https://www.toolstation.com/white-twin- ... ing/p20828
- wine~o
Looks exactly like the ones we used to use in a retail store, probably best to look for industrial/retail brackets.
- Has thanked: 285 times
- Been thanked: 402 times
Try searching with google lens , under the search bar in google there are a few search buttons and one of them is labelled shop with a screenshot.
Take a screenshot and then tap on the button , you will be prompted to load a photo from your photo library, once loaded google will search for that item.
It’s very simple to use .
Mike
Mike
Thanks for this suggestion - many hits but nothing matching my bracket.London mike 61 wrote: ↑Thu Oct 24, 2024 7:52 am Try searching with google lens , under the search bar in google there are a few search buttons and one of them is labelled shop with a screenshot.
- Has thanked: 807 times
- Been thanked: 3496 times
The critical thing here is the space between the hooks to marry up with the slots in the existing wall bracket. Buy two or three supports to replace all for that shelf run if you can find some that work. Do a pencil rubbing and have a wander into BnQ and Wickes to see what they have.
