Vent axia svara fan
Malctalk
Vent axia svara fan
Post by Malctalk »
Removed old vent axia fan connected to light switch,which had L..N..LS
Trying to connect new svara Bluetooth fan the connections are L…N..and one called T any help with the wiring of this fan please
Has thanked: 48 times
Been thanked: 2604 times
Vent axia svara fan
T is usually timed. BUT which fan do you have 12v or 240v and do the instructions say more about T?
Neelix
Has thanked: 118 times
Been thanked: 219 times
Vent axia svara fan
Post by Neelix »
How many cores are there in the cable at the existing fan
Malctalk
Vent axia svara fan
Post by Malctalk »
Have 240 volts
Old fan had 3 lines going into L-N-LS for the timed 5min turn off
This new one I’ve connected L-N-and LS into T
Just running continuously and have to adjust fan speed through App
OnlyMe
Approved Electrician
Has thanked: 225 times
Been thanked: 664 times
Vent axia svara fan
Post by OnlyMe »
So how do you want it to work?
Malctalk
Vent axia svara fan
Post by Malctalk »
On and off with light!
OnlyMe
Vent axia svara fan
Post by OnlyMe »
Try disconnecting the cable from the L terminal (make it safe as its mains voltage) and move the cable from the T terminal to the L terminal.
Malctalk
Vent axia svara fan
Post by Malctalk »
OnlyMe wrote: Sun Feb 09, 2025 11:00 am Try disconnecting the cable from the L terminal (make it safe as its mains voltage) and move the cable from the T terminal to the L terminal.
OK thanks I will give it a go
wine~o
Has thanked: 1415 times
Been thanked: 4030 times
Vent axia svara fan
Post by wine~o »
Malctalk wrote: Sat Feb 08, 2025 4:34 pm Bluetooth fan the connections are L…N..and one called T any help with the wiring of this fan please
"T" is for Timed, this needs a permanent live. (The timer needs power)
"L" is for the Switched live.
"N" is Neutral.
Quite why you need a bluetooth fan is beyond me though.
Return to “Electric Forum UK”
