Can't remove external window beading
Andersja88
Post by Andersja88 »
I am trying to renew a double glazing unit but the external window beading is proving to be a challenge. Unlike others I have done around the house, this window has a rubber strip between the outside bead and the window and it just won't budge. It looks as though there is foam security tape on the inside. Any advice on how to remove appreciated.
Has thanked: 740 times
Been thanked: 2355 times
picture off the inside may help
its not a normally constructed window as you have no clear frame between glass brick unless the 63mm ish frame is behind the bricks
you need a say 12mm x12m moulding that clips in on to the glass anything larger is added material not relevant to glass removal :dunno:
Has thanked: 48 times
Been thanked: 2604 times
Just saying, have you considered that the glass may have been installed from the inside?
Bob225
Has thanked: 106 times
Been thanked: 882 times
Post by Bob225 »
Pull the rubbers on the inside and pop the beads off - it's old style window with an external bead
I'm sure you will find a vid on Youtube
Return to “General DIY forum”
