Tiling on Marine/Eastern HW Ply
carhartt kid
Has thanked: 3 times
Been thanked: 1 time
Post by carhartt kid »
Hi.
Just want to know what preparation you have to make to attach grout to Ply, Its waterproof marine ply so I presume I have to do some kind of keying and paint on a prepapration of some kind????
Just not sure what though!!!
Thanks, Si
http://www.carhartt.com/
Has thanked: 1012 times
Been thanked: 918 times
Post by ultimatehandyman »
Mudster will tell you that marine ply is not the best surface to tile onto as it expands and contracts, so tile backer board is best.
However I used marine ply a few years ago and I just pva'd it and then tiled over it. Since reading mudsters advice I will never use PVA, unless the adhesvie manufacturers specify it.
Get the adhesive, which will need to be flexible as you are tiling onto wood and then get the primer that they specify. (if they specify one )
Marine ply should not really need a primer as it is not absorbant!
Mudster
Tiling Expert
Post by Mudster »
Where is it being used?
Flooring, walling, bathroom, shower?
carhartt kid
Its for a small shelf at the end of a bath. As seen below!
Bath Shelf.JPG (27.53 KiB) Viewed 3198 times
honeymonster
Post by honeymonster »
Just stick them on with waterproof tile adhesive that is suitable for wooden floors, you should not have a problem with them.
carhartt kid
I usually just key the surface with a criss-cross patter with a stanley knife and then prime the timber with a 1-5 PVA-Water mix. Its worked fine before but read a few posts on the forum and thought i'd ask???
Return to “Tiling Forum”
