glued wood joint
topura01
glued wood joint
Post by topura01 »
The best method to break a glued wood joint in furniture, the wood is mangrove
DAN GILL
wood4fun
Has thanked: 2 times
Post by wood4fun »
is the glue joint lose?
panlid
Been thanked: 1 time
Post by panlid »
topura, a man of few words and manners!
tim'll fix it
Post by tim'll fix it »
I find stamping on stuff is a good way of breaking it
Hitch
Has thanked: 77 times
Been thanked: 335 times
Post by Hitch »
I was told steam did the trick sometimes. It depends on what sort of glue though.
panlid
Post by panlid »
i agree with tims method. it depends on whether you want to keep the pieces or not :wink:
topura01
Post by topura01 »
wood4fun wrote:is the glue joint lose?
Thank you, the wood joint is not loose and I need to be able re-use once the joint is seperated
DAN GILL
Marc
Post by Marc »
Most properly glued joints are stronger than the wood and virtually impossible to part. The best method is usually to cut it.
wood4fun
Post by wood4fun »
Marc wrote:Most properly glued joints are stronger than the wood and virtually impossible to part. The best method is usually to cut it.
this is properly the only way you can do it. and if if you let us know what it is we can maybe suggest a new joint for you to make. picture :wink:
tim'll fix it
why do you want to break it
wood4fun
Post by wood4fun »
properly to big to fit into the room :lol: :lol:
Has thanked: 736 times
Been thanked: 2341 times
heeelllooo topura01 :grin: :grin: :grin:
the joints may be formed off mortice and tennons 'dowels or buiscuts
if its formed with mortice and tennons there could be nails screws or dowels as well as the glue holding the joint tight
they can be obvious or on the blind side
and on spray finnish furniture may be completly invisible
the joint could even just be butted up with screws and metal plates and dry locating dowels
i take it youve had a good look!!!
chippysmith
Professional Carpenter
Post by chippysmith »
Mangrove adhesive is made using tannin from bark.. it isn't a good glue due to the size of the molecules, they cannot move freely about their backbone :shock:
So inherently the glue becomes brittle. also not good in wet areas. so thats two lines of attack for you to persue :wink:
If it aint broke...... don't fix it
Marc
Post by Marc »
chippysmith wrote:Mangrove adhesive is made using tannin from bark.. it isn't a good glue due to the size of the molecules, they cannot move freely about their backbone :shock:
I think that means 'hit it' in English. :lol:
