How do I repair this (photo included) please?
R101
Post by R101 »
The concrete sill has disintegrated - what would be the best method to restore same?
Has thanked: 1012 times
Been thanked: 918 times
Post by ultimatehandyman »
You will never get a perfect colour match, but you can repair it with some repair mortar-
http://tinyurl.com/4xfvkrr
You can clamp a piece of wood on the underside and then fill the hole with the repair mortar and trowel it off flat, then when it has set remove the wood and the clamps.
You may have to fill the hole with a few thinner layers (if it starts to slump) by building it up gradually.
Last edited by ultimatehandyman on Fri Mar 06, 2009 5:08 pm, edited 1 time in total.
Geewizz
Has thanked: 7 times
Been thanked: 51 times
Post by Geewizz »
It would be prudent to cut off a portion of the top so that your fresh mortar wraps around the remaining portion. This will allow a better grip than a repair that only hangs onto the underneath of the existing original.
Phil
Advise rhymes with rise. Advice rhymes with rice.
R101
Post by R101 »
Thanks for the replies and the prudent tip Phil.
Is a 4Kg tub of the Epoxyset enough for that job?
Geewizz
Post by Geewizz »
It depends how much you drop. :lol: 4kg should be just enough though.
Phil
R101
Post by R101 »
OK - I'll post up a picture of the repair when done.
leebwk
Has thanked: 3 times
Been thanked: 31 times
Post by leebwk »
Any epoxy mortar will be able to repair that using methods suggested by previous poster but be aware that this was caused by water ingress causing the reinforcing bar to rust and blow the concrete apart so it maybe prudent to check the rest and take a bit of preventative action now such as sealing the over string courses or creating a small flaunch on top to throw the water off
Has thanked: 740 times
Been thanked: 2355 times
as scruff says clamp a bit off wood underneath but i would extend it forward a further 2" this will allow you to not drop so much and allow you to use a further bit off wood as a former
although you wont see much of the repair just remember to use smooth wood as the repair will take on the grain/rough surface off the wood
R101
Post by R101 »
thanks for the tips guys - epoxy mortar ordered.
thescruff
Has thanked: 360 times
Been thanked: 3735 times
Post by thescruff »
big-all wrote:as scruff says clamp a bit off wood underneath but i would extend it forward a further 2" this will allow you to not drop so much and allow you to use a further bit off wood as a former
That was the Boss BA not me :roll:
What I would do :roll: is, remove the old completely and make up a new piece using Bath stone or similar, then peg it into place using dowels, and then make good with bath stone dust and white cement. :thumbright:
R101
Post by R101 »
Here is a photo of the repair - thanks again for the help
Well done :thumbright:
