downlights
Locked
Dirk Diggler
downlights
Post by Dirk Diggler »
Hi guys, can any of you electrician fellows carify if i must use fire rated downlights in a bathroom that has only the loft space above it. i have had a lot of contradictory information about this in the past.
Dirk
[url=http://www.ultimatehandyman.co.uk/diy/decking/index.htm]Decking[/url] | [url=http://www.directory.ultimatehandyman.co.uk/plumbers/]Plumbers[/url]
Jaeger_S2k
Pro Handyman
Has thanked: 21 times
Been thanked: 27 times
Post by Jaeger_S2k »
Not a spark but no only restriction would be a sealed shower fitting if fitted above a shower.
Jaeger.
Dirk Diggler
thankyou for your quick reply jaeger, i cant help but smile at the stark disproportionate dichotomy represented by our avatars
sparkydude
Has thanked: 2 times
Been thanked: 149 times
Post by sparkydude »
You only have to use fire rated downlighters if it is below a habitable space, ie bedroom , if its the loft then no reason too. sometimes the fire rated can types can be useful in lofts as the can helps to keep insulation materials away from the lamp, and causing overheating. As jaeger says, make sure it si the right rating for the zone it is put in .
Nick
baldelectrician
Been thanked: 4 times
Post by baldelectrician »
In Scotland (under the Scottish building standards) you need them if there is another dewlling over your property.
If it's your bedroom (or your loft) then you don't
Locked
Return to “Lighting”
