Nice roof
This is where you can post pictures of extremely poor workmanship, whether it is done by a dodgy tradesman or by an incompetent DIY'er. Instructions on how to post pictures can be found in here.
Hitch
Has thanked: 77 times
Been thanked: 335 times
Nice roof
Post by Hitch »
Went to put a couple of bits of steel in a new extension roof...
Chippys got the ply nailed down, shame we had to pull it up again to get the steel in.
Still, uncouvered a few nice bits of carpentry ;)
Uses up the offcuts
Uses up the offcuts
Nice nailing
Nice nailing
Have another go!
Have another go!
StyXSIS
Has thanked: 27 times
Been thanked: 84 times
Re: Nice roof
Post by StyXSIS »
Now thats some screwed up work. Hope you told & showed the homeowner Hitch.
wine~o
Has thanked: 1415 times
Been thanked: 4031 times
Re: Nice roof
Post by wine~o »
:dunno: Measure once....mark-up twice....then just cut after a lunch down the pub???? :shock:
thescruff
Has thanked: 360 times
Been thanked: 3735 times
Re: Nice roof
Post by thescruff »
Probably gonna run the gas pipe in the spare notches. :lol:
Has thanked: 1012 times
Been thanked: 918 times
Re: Nice roof
Post by ultimatehandyman »
I'm amazed at the quality of some peoples work :shock:
I'm guessing that the carpenters made a real mess of it and you had to fix it using the steel?
Hitch
Re: Nice roof
Post by Hitch »
There was about 3 or 4 of them wrongly notched ones in various places :laughing:
All cut out with a circ saw too, the kerf is halfway across the reminder of he rafter
The engineer ballsed up, designed the roof with a tie across at head height... defeats the object of a vaulted ceiing :roll:
So we put in an extra bit to support the ridge, and stop the eaves spreading apart under the weight.
Shame about the chippy work really, everything else is a nice job. :roll:
royaloakcarpentry
Has thanked: 39 times
Been thanked: 621 times
Re: Nice roof
Post by royaloakcarpentry »
Nothing wrong in using a circular saw for the ends of the rafters, I wouldn't be sodding about doing the seat and plumb cuts with one though.
No excuse for work like that. Roofing isn't rocket science. All they needed to do was use two sheets of ply to mark ridge and plate onto and place rafter onto it and mark up...............no maths, no geometry, just the idiots full proof guide to marking rafters.
wadge
Has thanked: 4 times
Been thanked: 11 times
Re: Nice roof
Post by wadge »
Last time I cut a roof I used the previous rafter as the template for the next one. Problem with that is that a small marking error in one will lead to a small error in the next and so on.
Razor
Has thanked: 483 times
Been thanked: 1251 times
Re: Nice roof
Post by Razor »
wadge wrote:Last time I cut a roof I used the previous rafter as the template for the next one. Problem with that is that a small marking error in one will lead to a small error in the next and so on.
That's why you write Pat on the first one :lol:
diyguys
Has thanked: 178 times
Been thanked: 19 times
Re: Nice roof
Post by diyguys »
Whos pat :dunno:
Gadget
Jack Of All Trades
Has thanked: 347 times
Been thanked: 344 times
Re: Nice roof
Post by Gadget »
diyguys wrote:Whos pat :dunno:
Pat Butcher, from Eastenders!
By eck! ©
royaloakcarpentry
Re: Nice roof
Hmmmmm walls being out............had that years ago, we could tell the building was out of square just by looking at it but the site agent insisted everything was bang on, as he had been checking. It was meant to have 6" soffit and although 3 sides were 6" the 4th side of the building was 6" increasing to 8" pmsl. Trussed roof too and so not a lot that could be done except pass the buck back to the site agent.
BenjaminS
Has thanked: 13 times
Been thanked: 3 times
Re: Nice roof
Post by BenjaminS »
Shameful, i'm not pro but I know a rubbish job when I see one! :sad: :wtf: I sincerely hope someone more competent is working the job, or complete it. For some reason the program Cowboy Builders come to mind!
mike_odonovan
Re: Nice roof
Post by mike_odonovan »
the really dumb thing is that these ****ups would actually chew up a lot of time. so bad job and probably took as long as it would to do it well.
Return to “Rogues Gallery”
