Rubber roofs an absolute bugger to lay.
Diy disaster stories in this forum please, Tradesmen disaster stories are also welcome in here!
Locked
Puma
Has thanked: 681 times
Been thanked: 709 times
Post by Puma »
Having just spent ages laying a Firestone rubber roof and not getting a particularly good result, I just thought I'd put a heads up in here.
If you lay whilst the glue is wet it slides around as bad as ice when you stand on it, if you lay when tacky it is really difficult to get it right first time. Furthermore the edges should be stuck down with contact adhesive, this has to be tacky or the rubber expands nightmarishly if it is wet - it still swells and bubbles a little when stuck down with dry/tacky glue. Extremely hard to get right.
Wish I had gone for polymer reinforced render.
These users thanked the author Puma for the post:
BRUNO
BRUNO
Has thanked: 34 times
Been thanked: 67 times
Re: Rubber roofs an absolute bugger to lay.
Post by BRUNO »
Cheers for that. Looking at their videos it looks as easy as laying out a rug
Locked
Return to “DIY Disasters”
