Guttering
Grumpy people only in here please
Locked
Has thanked: 1012 times
Been thanked: 918 times
Guttering
Post by ultimatehandyman »
How difficult can it be to source some square line guttering?
The gutter on the garage was leaking, so I thought I’d pop in some new gaskets to fix the problem, when I went to fit the new gaskets I realised that some plonker had cut the gutter short by an inch- on both pieces, so really it needed a new piece of guttering.
At the far side of the garage there is no gutter and so the water run off goes onto next door neighbours flat roof, so I’m putting up a new gutter on that side also. There is no drain for the water to run into at the moment- it simply runs into the garden, so I am fitting a water butt as well.
Measured up and checked the Tradepoint catalogue- all items were pick yourself. I picked up a trolley on the way in and picked up 5 lengths of square line guttering, by this time it was 20:00. Guess what! Yep, they had no running outlets, or gutter unions and were also missing a few other square line items ::b
Drive home the 5 miles (wasted journey) and made a list from the Travis Perkins website as one of the guys in there said he would give me a good price. Went in and he was not there but this other guy said he could give me a good price, he worked everything out and was out of stock for a couple of items, so he calls Blackburn branch and they have the stuff in stock. He gives me an account number which I hand in at the Blackburn branch, the guy behind the counter grabs a carrier bag and starts filling it on the shop floor with square line guttering fittings, he then notices that some of the stuff I need is out of stock ::b So now I have been to Blackburn twice and wasted hours of my time and 20 miles worth of fuel for nothing ::b
Then I remembered Screwfix in Blackburn who had everything in stock
What is the point of stocking an item, if you are going to allow yourself to be out of stock on some items? It is not like you can use a round line gutter union if there are no square line unions :cussing:
happy handyman
Has thanked: 177 times
Been thanked: 135 times
Re: Guttering
Post by happy handyman »
Had a similar issue , you want to try replacing a few pieces from square line guttering from years ago, there are several profiles !
My advise, stick with Flowplast guttering, sold at Screwfix, market leader and you will always get spares ! I know Travis Perkins use a different make , so there maybe silver lining in it ....in years to come !
This is a guide I used ....
http://www.floplast.co.uk/uploads/downl ... 0Guide.pdf
Re: Guttering
I think Travis Perkins sell OSMA.
Thanks for the guide :thumbright:
I removed the old guttering today and painted the boards with two coats of Zinsser 123, then a top coat of Dulux weathershield Gloss.
It took ages removing the bits of crap left over from when I removed the Ivy a few months back- awful stuff ::b
I can feel another grumpy post coming :lol:
happy handyman
Re: Guttering
Do you know what the gradient is as a percentage for the guttering ? Can't get my head around it...?
I've ordered one of those digital levels specially !
Re: Guttering
Normally I fit it at a fall of between 1mm and 3mm per metre. I believe you can install it dead level, but I would never do that!
The gutter I am fitting is 6m long so I'll drop the outlet end by 6mm
These users thanked the author ultimatehandyman for the post:
happy handyman
philprime
Has thanked: 77 times
Been thanked: 247 times
Re: Guttering
Post by philprime »
I always use 5mm fall over 3 mtrs when fitting guttering
Wardsta
Has thanked: 22 times
Re: Guttering
Post by Wardsta »
Good old Screwfix, my favourite hardware outlet only because it is the nearest to my place of work. I have Screwfix, Toolstation, B&Q, Plumbase and Homebase all within a 5 min drive and Scewfix is the one i use 95% of the time.
Locked
Return to “The Grumpy corner”
