How many spotlights to replace fluorescent strip light?
Locked
MarkJP
Post by MarkJP »
I am currently refitting a kitchen which measures 3.4 x 2.5 metres (11' x 8'6'), which is currently lit by a 1.5 m (5') long fluorescent strip light. The wife wants to dispense with the strip light and install a more stylish looking set of 4 spot lights, but does not want a darker kitchen. How many conventional incandescent light bulbs or halogen or tungsten spot lights would I need to match the fluorescent light output?
Hinton Heating
Gas/Heating Expert
Been thanked: 9 times
Re: How many spotlights to replace fluorescent strip light?
Post by Hinton Heating »
MarkJP wrote:I am currently refitting a kitchen which measures 3.4 x 2.5 metres (11' x 8'6'), which is currently lit by a 1.5 m (5') long fluorescent strip light. The wife wants to dispense with the strip light and install a more stylish looking set of 4 spot lights, but does not want a darker kitchen. How many conventional incandescent light bulbs or halogen or tungsten spot lights would I need to match the fluorescent light output?
It depends upon the brightness of teh spotlights you want to install. What wattage is each one?
Has thanked: 1012 times
Been thanked: 918 times
Post by ultimatehandyman »
Light output is measured in Lumens, if I remember rightly.
A flourescent tends to spread light in all directions whilst spot lights direct the light in one direction. There are lots of factors to consider such as will all 4 spot lights be in a line or will they be a distance apart. Or where you thinking of a rail that has the spot lights on like the picture attached?
For a rough guess I would say 4, but that is just a guess- or get one like the light in the attached picture.
Stoday
Deceased 21-10-2011 R.I.P
Has thanked: 8 times
Been thanked: 90 times
Post by Stoday »
The luminous efficiency of filiament lamps is around 15 lumens per watt, fluorescent 80 Lm/W.
So you need 300 W of lamps in total. So if you have four, each should be 75W. Or six at 50W.
This is only a broad comparison; as pointed out above there are other factors than just the lumen output to consider.
markysparky
Electrician
Contact:
Post by markysparky »
You can now actually get fluorescent recess lights now. They are only 7watt and obviously not as bright as the halogen bullbs.
No info on the net for them. But I did get have a leaflet about them from the wholesalers.......somewhere
Locked
Return to “Lighting”
