Hi guys
Can anyone help me with an assembly problem with a Howdens standard corner carousel?
It is at
https://www.howdens.com/kitchen-collect ... -carousel/
It does not have assembly instructions in the pack, and it doesn't feature in the Fitted Kitchens manual that Howdens supplied.
There doesn't seem to be a way to lock the supporting rod, as although a metal pin is provided, I can't see how it stays in.
Any help would be gratefully received.
Thanks very much
Phil
- Chop
- Has thanked: 304 times
- Been thanked: 219 times
Re: Howdens standard corner carousel
Have you got a pic of the part you mean?
Is it the pin to set the height of the pole
or the pin to support the height of the shelf?
- ayjay
- Has thanked: 458 times
- Been thanked: 1708 times
I seem to remember (quite vaguely) that there's a plastic sleeve that fits over the pin once it's in the supporting pole, either that or the shelf provides the sleeve - long time since I did one of those, all the ones I've fitted recently have been the pull-out type.
Phone them up and ask for a set of instructions.
