From the top down......
24 port patch
16 Port Netgear gigabit switch
Draytek Router
Synology 215j 2x3tb WD reds (Media)
Synology 215j 2x2tb WD reds (Backup)
Synology 115j 1x2tb WD re Yellow (Ip cameras)
Swan 4ch dvr what will be replaced by the above 115j
Buffalo Diskstation Currently 4 tb Master backup
Rest of the network
Temp Netgear powerline 1200 adapters feeding a 8 port Netgear gigabit switch for the front room
5 Port Netgear gigabit switch upstairs feeding a inkjet, Colour Laser and a Draytek AP
2 cat6 feeds, feeding the workshop's 16 port Netgear Gigabit (split lan and vlan)
Most of the house is hardwired the rest gets done as and when it gets redecorated (upgraded as needed)
All Switches are the fanless and are the Netgear Prosafe range
Plans for the future
Ip Cameras with a 8 port POE switch (keep the data off the main network)
Upgrade the wireless, 5ghz AC seems the way forward
Swap out the 16 port switch as its nearly full
Fibre backbone
