TIles have changed colour...
- Has thanked: 2 times
- Been thanked: 2 times
Leaking shower
Hello,
The sealant in my shower is split and clearly leaking because a couple of my tiles have gone dark, presumably because they're soaking up water. I can repair the sealant but I'm not sure what to do about the tiles. Will they dry out if I repair the sealant? Any advice would be much appreciated. Thanks.
- Mr. Grumpy
- Has thanked: 25 times
- Been thanked: 109 times
Hello,
The sealant in my shower cubicle has split vertically in the corner and is clearly leaking because a couple of my ceramic, white, wall tiles have gone dark, presumably because they're soaking up water. I can repair the sealant but I'm not sure what to do about the tiles. Will they dry out if I repair the sealant? Any advice would be much appreciated. Thanks.
- moderator2
- UHM Super Moderator
- Has thanked: 154 times
- Been thanked: 566 times
- wine~o
- Has thanked: 1414 times
- Been thanked: 4015 times
Re: Leaking shower
No they won't dry out. They need removing first, then depending on how bad the water damage is behind you'll either need to hack off any damp plaster and allow the wall to dry out before re-plastering or remove / replace any damaged plaster board behind the tiling.MollyImms wrote:Hello,
Re-tile once dry and remove and replace all the sealant.
