Should have been a freeby
zedhead
Has thanked: 64 times
Been thanked: 19 times
Post by zedhead »
I had some materials left over from a decking job when the punter changed her mind so asked the mrs to lay out the boards and show me what she wanted, I thought she only wanted a bit by the back door!!!... £500 later
IMG_0987 (Small).JPG (123.19 KiB) Viewed 3977 times
IMG_0988 (Small).JPG (114.44 KiB) Viewed 3977 times
IMG_1028 (Small).JPG (111.69 KiB) Viewed 3977 times
Baza
mikew1972
Has thanked: 10 times
Been thanked: 110 times
Re: Should have been a freeby
Post by mikew1972 »
I like that. :thumbleft:
Works well with the angled boards and very neat around the manhole access.
Mike
Wes
Wood Flooring Installer
Has thanked: 379 times
Been thanked: 565 times
Post by Wes »
Looks well that...I've got a sore neck though :lol: Right click on the pic where you've saved it, hit 'rotate', simples :mrgreen:
Has thanked: 1415 times
Been thanked: 4024 times
Wes wrote:Looks well that...I've got a sore neck though :lol: Right click on the pic where you've saved it, hit 'rotate', simples :mrgreen:
I had to turn my laptop on it's side........ :?
Zedhead.... I hope you haven't put the deck bearers directly on the patio slabs without a DP Membrane??
steviejoiner74
Has thanked: 747 times
Been thanked: 1616 times
Post by steviejoiner74 »
They'd get soaking wet anyway wine-o,on a low level deck I usually sit the joists on concrete blocks on flat and up a few inches from ground level.
I know it's not good practice to sit timber on ground but with decking it's sometimes unavoidable.
The main thing to try and avoid is end grain sitting on ground level.
Concur, even if it's just a slab off a patio...get it off the ground wherever possible, a bit of air flow underneath prolongs the life of the deck....
moderator2
UHM Super Moderator
Has thanked: 155 times
Been thanked: 569 times
Post by moderator2 »
Issi noho
Baz 1.JPG (128.35 KiB) Viewed 3884 times
These users thanked the author moderator2 for the post:
zedhead
zedhead
Post by zedhead »
Sorry about pics I only sussed how to post em today.. Will work it out eventually lol
Baza
zedhead
Post by zedhead »
Only the front bearers are in place in the pictures the rest went in after that, the ones on the concrete slab are on dpc and the ones on the grass are concrete brick and dpc (I always put em in when the frame is built).... Some of the timbers by the original step are very close to the original slab but I needed to get the step height and the bit down the side (that you can't see) right.... will get the picture malarky sorted eventually lol
Baza
zedhead
Post by zedhead »
Issi noho
Thank you... How did you do that ? I have no edit option on the post with the pictures
Baza
Return to “Show Case Gallery”
