Boiler housing and surrounding units Hight problem.
nick200
Has thanked: 409 times
Been thanked: 222 times
Re: Boiler housing and surrounding units Hight problem.
Post by nick200 »
manny wrote:
nick200 wrote: We have just fitted a kitchen (well almost) and our boiler cupboard is in the corner like yours but it is deeper not higher. Now yes you can just see the flue but we minimised this by cornice/pelmet (?) along the top. I did have to remove a lot of the cupboard and strengthen it for this to work.
This will mean I will have to cut down the gloss door and reposition the hinges etc etc. lol this is my first attempt at a kitchen fit. Seems like a lot of work. I might mess it up.
I would not do it either so maybe I would not recommend it for you. If I felt really confident I might try cutting a section out of the middle of the cupboard and then secure together using dowels/metal plates but I would have to be having a very good day!
I think the first question is whether a different size height cupboard could work (check the design), if it could then I would bite the bullet and buy a smaller height cupboard and door. Our boiler cupboard is deeper than the others but we are lucky that it can be the same height. You would have to make sure that there was plenty of access around the boiler maybe speak to your boiler person?
Nick
philprime
Has thanked: 77 times
Been thanked: 247 times
Post by philprime »
manny wrote:This will mean I will have to cut down the gloss door and reposition the hinges etc etc. lol this is my first attempt at a kitchen fit. Seems like a lot of work. I might mess it up.
Kitchen fitting is just a giant jigsaw puzzle without instructions!!!
Do the sockets have to be there!!
manny
Has thanked: 63 times
Post by manny »
I have been repositioning the height of the boiler housing.
If I bring it down to just above the sockets(mm's above) I'm left with a gap of approx 620mm for the surrounding wall units.
Is this acceptable?
thescruff
Has thanked: 360 times
Been thanked: 3735 times
Post by thescruff »
Whats important is the measurement above and to the sides of the cooker.
Can I assume you'll need to lean over the cooker to reach/use the sockets :shock:
manny
Post by manny »
thescruff wrote:Whats important is the measurement above and to the sides of the cooker.
No, as I have sockets on either side of where the cooker will go.
I have sockets on all three walls of the kitchen.
thescruff
Post by thescruff »
Must be the drawing then because the ones on the left look close, what have you got a 300mm gap between the range and the unit ?
Manny Kitchen.jpg (113.53 KiB) Viewed 2022 times
manny
Post by manny »
thescruff wrote:Must be the drawing then because the ones on the left look close, what have you got a 300mm gap between the range and the unit ?
Yeh your right mate. The cooker switch socket is terribly close to the cooker. That might have to get moved.
The normal power socket and boiler spur are ok.
I don't even need the cooker switch socket as I will be having a all gas cooker.
But we decided to keep in the cooker wire from mains just incase we sell the house in future etc.
Return to “Kitchen Fitting”
