Using Contact adhesive to seal sink cut out.
manny
Has thanked: 63 times
Post by manny »
Would this be ok to use. As I have some leftover. Or is there a better solution?
Chris Skilbeck
Has thanked: 132 times
Been thanked: 238 times
Re: Using Contact adhesive to seal sink cut out.
Post by Chris Skilbeck »
Hi Manny,
In theory I'm sure contact adhesive would make a good seal - but it's a lot easier to use a mastic-type seal, silicon, or my preferred choice, Geocell 'The Works' - easy to spread and press into the cut surface, easy to wipe away excess (use a 'Wonder Wipe' or similar).
Keep your contact adhesive for a job you specifically need it for, and keep the rest of the Geocell for any of the hundreds of jobs it's good for (it's a strong adhesive as well as a sealant).
ayjay
Has thanked: 458 times
Been thanked: 1708 times
Post by ayjay »
I prefer to use two coats of Evostik 528 (contact adhesive) if I have it with me at the time, otherwise I'll use silicone (one good coat) or PVA (three coats).
The PVA takes ages to dry with three coats, silicone less so and the Evo is quickest of all.
If your leftover contact adhesive is getting a bit old and thick it would be better to use something else.
Rorschach
Has thanked: 126 times
Been thanked: 1045 times
Post by Rorschach »
I use silicone (black usually) to seal cut worktops.
The man with no aim
manny
Post by manny »
Anyone ever used oil based u/c or gloss to seal?
And thanks for all the replies and input.
Rorschach
Post by Rorschach »
manny wrote:Anyone ever used oil based u/c or gloss to seal?
I wouldn't have thought it as good as just using a bit of cheap silicone, probably just soak into the chipboard and still leave gaps.
steviejoiner74
Has thanked: 747 times
Been thanked: 1616 times
Post by steviejoiner74 »
I use contact adhesive,it goes off really quickly.
fin
Has thanked: 32 times
Been thanked: 816 times
Post by fin »
i go with silicone,. never thought to use contact adhesive to seal it before.
using a track saw to cut sinks out makes it easier to seal the edges. less raggyness
OnlineOnline
manny
Post by manny »
Have some contact adhesive left over from a job a while go, is it still usable:
ayjay
Post by ayjay »
manny wrote:Have some contact adhesive left over from a job a while go, is it still usable:
That looks like the Thixotropic stuff of which I have very little experience, (tried it once and didn't like it) - but it's still a contact adhesive, I guess if it spreads without any trouble it'll do the trick.
Rorschach
Post by Rorschach »
If you can spread it then you can use it. I had Ok luck with thinning some contact adhesive with acetone once, I really needed to get the job done, in future I would just buy new though.
Return to “Kitchen Fitting”
