- Ultimate Handyman Forum Index DIY Forum/Home improvement Carpentry/Joinery Forum Kitchen Fitting
- It is currently Sat Apr 05, 2025 8:28 am
Using Contact adhesive to seal sink cut out.
- Has thanked: 63 times
Would this be ok to use. As I have some leftover. Or is there a better solution?
manny
- Chris Skilbeck
- Has thanked: 132 times
- Been thanked: 238 times
Re: Using Contact adhesive to seal sink cut out.
Post by Chris Skilbeck »
Hi Manny,
In theory I'm sure contact adhesive would make a good seal - but it's a lot easier to use a mastic-type seal, silicon, or my preferred choice, Geocell 'The Works' - easy to spread and press into the cut surface, easy to wipe away excess (use a 'Wonder Wipe' or similar).
Keep your contact adhesive for a job you specifically need it for, and keep the rest of the Geocell for any of the hundreds of jobs it's good for (it's a strong adhesive as well as a sealant).
Chris Skilbeck
- ayjay
- Has thanked: 458 times
- Been thanked: 1708 times
I prefer to use two coats of Evostik 528 (contact adhesive) if I have it with me at the time, otherwise I'll use silicone (one good coat) or PVA (three coats).
The PVA takes ages to dry with three coats, silicone less so and the Evo is quickest of all.
If your leftover contact adhesive is getting a bit old and thick it would be better to use something else.
ayjay
- Has thanked: 120 times
- Been thanked: 1043 times
I use silicone (black usually) to seal cut worktops.
- These users thanked the author Rorschach for the post:
- The man with no aim
Rorschach
Anyone ever used oil based u/c or gloss to seal?
And thanks for all the replies and input.
manny
I wouldn't have thought it as good as just using a bit of cheap silicone, probably just soak into the chipboard and still leave gaps.manny wrote:Anyone ever used oil based u/c or gloss to seal?
Rorschach
- steviejoiner74
- Has thanked: 747 times
- Been thanked: 1616 times
Post by steviejoiner74 »
I use contact adhesive,it goes off really quickly.
steviejoiner74
- Has thanked: 32 times
- Been thanked: 816 times
i go with silicone,. never thought to use contact adhesive to seal it before.
using a track saw to cut sinks out makes it easier to seal the edges. less raggyness
fin
Have some contact adhesive left over from a job a while go, is it still usable:
manny
- ayjay
That looks like the Thixotropic stuff of which I have very little experience, (tried it once and didn't like it) - but it's still a contact adhesive, I guess if it spreads without any trouble it'll do the trick.manny wrote:Have some contact adhesive left over from a job a while go, is it still usable:
ayjay
If you can spread it then you can use it. I had Ok luck with thinning some contact adhesive with acetone once, I really needed to get the job done, in future I would just buy new though.
Rorschach
