How to Remove Rust Faster?
ugoleaf
Has thanked: 120 times
Been thanked: 4 times
Post by ugoleaf »
Rorschach A lot of dark matter came off, leaving stains. Should I dry and use sandpaper again or straight into bicarbonate soda it goes?
Rorschach
Has thanked: 108 times
Been thanked: 1038 times
Post by Rorschach »
Those dark stains are the rust that has been converted by the treatment. A quick rinse with bicarb and then a good scrub with WD40 (scouring pad ideally) should clean it up nicely.
ugoleaf (Mon Dec 06, 2021 4:58 pm)
ugoleaf
Post by ugoleaf »
Rorschach Should I leave it in bicarbonate soda with water overnight?
Rorschach
Post by Rorschach »
No, a minute or two will be plenty.
ugoleaf (Mon Dec 06, 2021 7:24 pm)
ugoleaf
Post by ugoleaf »
Grendel wrote: Sun Dec 05, 2021 9:08 am I've used wet and dry paper with brasso and that seemed to work better than just the sandpaper on it's own.
What is wet paper and what is dry paper?
Has thanked: 47 times
Been thanked: 2572 times
ugoleaf wrote: Wed Dec 08, 2021 11:07 amWhat is wet paper and what is dry paper?
Believe it or not you can also get "wet and Dry" sandpaper.
ugoleaf
Post by ugoleaf »
Someone-Else wrote: Wed Dec 08, 2021 12:30 pm Believe it or not you can also get "wet and Dry" sandpaper.
I guess I can always put paper under tap water and dry it but I thought there's a special kind of paper...
ugoleaf
Post by ugoleaf »
Rorschach After two cycles of overnight citric acid and baking soda finale I think it will take a few weeks to bring USSR ruler back and make it great again using 800 grit sandpaper. Unless I want to go that route maybe I should use a fine file tool to speed things up? Although a nice polished ruler would be something Golumn would buy.
............all the TIME and effort, you can buy a new one for £11
ugoleaf
Post by ugoleaf »
Someone-Else wrote: Fri Dec 10, 2021 4:22 pm ............all the TIME and effort, you can buy a new one for £11
You will never find USSR made stainless steel ruler.
ugoleaf wrote: Fri Dec 10, 2021 5:23 pmYou will never find USSR made stainless steel ruler.
Yes I will, there is a set of 3 on ebay
ugoleaf
Post by ugoleaf »
Someone-Else wrote: Fri Dec 10, 2021 7:30 pm
I can't believe this... I have failed my mission... All was in vain... :shock:
