- It is currently Tue Apr 08, 2025 12:26 pm
Cutting out recess in plasterboard
- Argyll
- Has thanked: 1193 times
- Been thanked: 584 times
I've watched a few US Youtube videos when they cut out drywall using a rotozip thing. I just wondered if they have a similar thing here in the UK? I don't want to buy the full tool just an attachment I can fit on my trim router. Is there such a thing here?
Edit: I just spotted this but wonder if I can just buy the attachment?
https://www.screwfix.com/p/makita-dco18 ... lsrc=aw.ds
Argyll
- Has thanked: 48 times
- Been thanked: 2606 times
Over here most folk use a multi tool. Not only can you use it on plasterboard you can cut floorboards too.
- Argyll
Actually, I might just leave it. I thought the cutter worked along the same lines as a bearing router bit but it doesn't. Like this:
It's handy if it's metal behind it so the cutter will follow the edge of the metal but I'm cutting out a recess on a media wall. The recess is also made of plasterboard so the cutter might cut into it.
I think these things are really only good for cutting out sockets with metal back boxes. I don't do enough of that work to justify spending around £100.
I wanted to attach the plasterboard then cut out the plasterboard in situ. I'll just have to use my laser level now and cut out with my multi tool.
- c196x1_2tc_3d1_7.jpg (19.81 KiB) Viewed 2484 times
Argyll
- Argyll
Yeah but the rotozip thing follows the back box behind it making a neat cut.Someone-Else wrote: ↑Wed Feb 23, 2022 3:34 pm Over here most folk use a multi tool. Not only can you use it on plasterboard you can cut floorboards too.
Argyll
- Argyll
I wanted to fit the plasterboard and cut out the recess for the Tv and Skybox in situ. The photo gives a better idea.
The TV recess is encased with plasterboard now.
- IMG_20220221_124853.jpg (578.29 KiB) Viewed 2484 times
Argyll
- Has thanked: 94 times
- Been thanked: 128 times
I use one of these. For a straight cut I follow a straight edge fixed to the work. I mainly use mine for cutting out for back boxes. I would think that other brands will have the same thing on sale.
- Ryobi speed saw.jpg (143.76 KiB) Viewed 2479 times
stevei
- Has thanked: 740 times
- Been thanked: 2355 times
i bought the ryobi one about 15 years ago as a possible donner to the imported p600 18v router but not interchangeable so never used
do have ryobi batteries your end argyle ??
- Argyll
Cheers Stevie but the back of it is also plasterboard so it would probably cut into it as well.
Argyll
- Argyll
Argyll
i will try and dig it out and check its all there and working and get back to you
- Has thanked: 61 times
- Been thanked: 184 times
Aren't those tools doing the same job as a dremel? Dremel sell a depth attachment for cut outs.
ahfix
found it any good to you ??
- Has thanked: 833 times
- Been thanked: 3633 times
Would a simple saw be best? https://www.screwfix.com/p/c-k-5tpi-woo ... /1046x#_=p rough cut and finish with a Surform perhaps? I gave my Rotazip away having never used it, an impulse buy from Aldi.
- Argyll
Exactly what I did mate but one of those rotozip things would certainly come in handy in future. I think next time I'll screw on a 2mm metal strip on the inside to use as a straight guide for the rotozip and remove when I'm done.dewaltdisney wrote: ↑Thu Feb 24, 2022 10:17 am Would a simple saw be best? <span class="skimlinks-unlinked">https://www.screwfix.com/p/c-k-5tpi-woo ... #_=p</span> rough cut and finish with a Surform perhaps? I gave my Rotazip away having never used it, an impulse buy from Aldi.
Argyll
