Cutting out recess in plasterboard
Argyll
Has thanked: 1192 times
Been thanked: 583 times
Post by Argyll »
I've watched a few US Youtube videos when they cut out drywall using a rotozip thing. I just wondered if they have a similar thing here in the UK? I don't want to buy the full tool just an attachment I can fit on my trim router. Is there such a thing here?
Edit: I just spotted this but wonder if I can just buy the attachment?
https://www.screwfix.com/p/makita-dco18 ... lsrc=aw.ds
Has thanked: 48 times
Been thanked: 2605 times
Over here most folk use a multi tool. Not only can you use it on plasterboard you can cut floorboards too.
OnlineOnline
Argyll
Post by Argyll »
Actually, I might just leave it. I thought the cutter worked along the same lines as a bearing router bit but it doesn't. Like this:
It's handy if it's metal behind it so the cutter will follow the edge of the metal but I'm cutting out a recess on a media wall. The recess is also made of plasterboard so the cutter might cut into it.
I think these things are really only good for cutting out sockets with metal back boxes. I don't do enough of that work to justify spending around £100.
I wanted to attach the plasterboard then cut out the plasterboard in situ. I'll just have to use my laser level now and cut out with my multi tool.
Argyll
Post by Argyll »
Someone-Else wrote: Wed Feb 23, 2022 3:34 pm Over here most folk use a multi tool. Not only can you use it on plasterboard you can cut floorboards too.
Yeah but the rotozip thing follows the back box behind it making a neat cut.
Argyll
Post by Argyll »
I wanted to fit the plasterboard and cut out the recess for the Tv and Skybox in situ. The photo gives a better idea.
The TV recess is encased with plasterboard now.
stevei
Has thanked: 94 times
Been thanked: 128 times
Post by stevei »
I use one of these. For a straight cut I follow a straight edge fixed to the work. I mainly use mine for cutting out for back boxes. I would think that other brands will have the same thing on sale.
Ryobi speed saw.jpg (143.76 KiB) Viewed 2461 times
Has thanked: 740 times
Been thanked: 2355 times
i bought the ryobi one about 15 years ago as a possible donner to the imported p600 18v router but not interchangeable so never used :scratch:
do have ryobi batteries your end argyle ??
Argyll
Post by Argyll »
Cheers Stevie but the back of it is also plasterboard so it would probably cut into it as well.
Argyll
Post by Argyll »
Al I have a badaptor from Ryobi to DeWalt
big-all (Wed Feb 23, 2022 6:19 pm)
i will try and dig it out and check its all there and working and get back to you :huray:
ahfix
Has thanked: 61 times
Been thanked: 184 times
Post by ahfix »
Aren't those tools doing the same job as a dremel? Dremel sell a depth attachment for cut outs.
found it any good to you ??
Has thanked: 831 times
Been thanked: 3630 times
Would a simple saw be best? https://www.screwfix.com/p/c-k-5tpi-woo ... /1046x#_=p rough cut and finish with a Surform perhaps? I gave my Rotazip away having never used it, an impulse buy from Aldi.
OnlineOnline
Argyll
Post by Argyll »
dewaltdisney wrote: Thu Feb 24, 2022 10:17 am Would a simple saw be best? <span class="skimlinks-unlinked">https://www.screwfix.com/p/c-k-5tpi-woo ... #_=p</span> rough cut and finish with a Surform perhaps? I gave my Rotazip away having never used it, an impulse buy from Aldi.
Exactly what I did mate but one of those rotozip things would certainly come in handy in future. I think next time I'll screw on a 2mm metal strip on the inside to use as a straight guide for the rotozip and remove when I'm done.
Return to “Tool Talk”
